PROBLEM
When drawing a table frame in an ArcGIS Pro layout, the table data is not displayed in the table frame.
Depending on the cause, use one of the following solutions.
Adjust the map frame extent
If the features are not visible on the map frame, adjust the map frame extent by dragging the sides of the map frame until all the features are visible in the table frame. Refer to ArcGIS Pro: Modify a map frame for additional instructions.
Insert a new table frame
An alternative to adjusting the map frame extent is to insert a new table frame. In the Contents pane, under Map Frame, select the desired layer and draw a new table frame. Refer to ArcGIS Pro: Insert a table frame for further instructions.
Configure the table frame data source to the map frame
Set the data source to the map frame by configuring the table frame.
The image below displays the table frame with existing data in the layout view of ArcGIS Pro.
Article ID: 000032374
Get help from ArcGIS experts
Start chatting now
