HOW TO
Elevation points represent the vertical positioning of the land surface, encompassing measurements in the x, y, and z dimensions. Utilizing a digital elevation model (DEM) facilitates the retrieval of elevation information to create elevation points. This method helps determine the elevation of landforms within a designated topographic area, including valleys and hills. In ArcGIS Pro, existing tools can derive elevation points from a DEM, depending on the desired output data.
The image below shows a DEM with several point features. Each of these features represents a unique elevation value derived from the DEM.
Note: The Elevation Point From DEM tool requires an ArcGIS Topographic Mapping license.
The Elevation Point From DEM tool adds elevation points to the map by interpolating elevation values from the DEM. When the map point is created, this elevation value is automatically calculated from the raster. Refer to ArcGIS Pro: Create elevation points from a DEM for instructions.
Note: The Add Surface Information tool requires a 3D Analyst license.
The Add Surface Information tool adds the attributes of input features with height-based statistical information derived from the overlapping surface.
The image below shows the elevation information of point feature classes derived from the DEM using the Add Surface Information tool.
The Summarize Elevation calculates the statistical summary of elevation for each input feature.
Note: This tool summarizes the elevation, slope, and aspect information for the input features. The returned elevation values are measured in meters.
The image below shows the elevation information of point feature classes derived from the DEM using the Summarize Elevation tool.
Article ID: 000031174
Get help from ArcGIS experts
Start chatting now
