ERROR
When compiling or executing a Java application that uses the ArcObjects Java API, the following error is returned:
Error: java.lang.UnsatisfiedLinkError: no ntvinv in java.library.path
The PATH variable does not include a directory which contains the native libraries required for ArcObjects Java classes to function.
Add the directory containing the native libraries required by ArcObjects Java to the PATH variable.
A. $ARCENGINEHOME\java\jre\bin
B. $ARCENGINEHOME\bin
$ARCENGINEHOME may have to be replaced with the location of the ArcGIS SDK installation.
Article ID: 000007942
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
