English
FAQ: Is Windows 10 certified with Esri's ArcGIS products?
Question
Answer
Windows 10 Home, Pro, and Enterprise (32 bit and 64 bit [EM64T]) has been tested and certified with ArcGIS 10.3.1 for Desktop through ArcGIS Desktop 10.5.
Windows 10 Home, Pro, and Enterprise (64 bit) has also been tested and certified with ArcGIS Pro 1.3.
With ArcGIS for Server, Windows is supported for basic testing and application development use only. Windows 10 Pro and Enterprise have been tested and certified with ArcGIS Enterprise 10.5.
Version 100.0 of the ArcGIS Runtime SDKs for .NET, Java, and Qt are certified for use on Windows 10.  In addition, version 100.0 of the ArcGIS Runtime SDK for .NET includes a new API to build Universal Windows Platform (UWP) apps for Windows 10.  ArcGIS Runtime SDK versions 10.2.6 and prior will not be certified on Windows 10.
We will continue to post updated information regarding Windows 10 support to this KB article and to the System Requirements pages when the information becomes available.
Licensing Issue
For those running ArcGIS 10.3.1 and upgrading to Windows 10, when launching ArcGIS for Desktop, ArcGIS Administrator, or ArcGIS License Manager, the following error message may be received:
"The ArcGIS Server Administrator has detected that your license have become untrusted. This can occur when a machine hardware configuration has changed or licenses have been restored from a backup. Please click the 'Repair' button below to repair your untrusted licenses."
If this occurs, follow the procedure listed below.
Procedure
If Trusted Storage is in an 'untrusted' state, it must be repaired. Each license is allotted a set number of repairs to accommodate the vast majority of deployments under normal conditions.
  1. Open ArcGIS Administrator (or ArcGIS License Server Administrator) and navigate to the Authorization folder from the left panel.
  2. Under 'Version', select the version of the authorized software, and click Repair.
  3. Once the repair is complete, confirm the availability of the licenses by selecting Availability from the left panel.
If the repair operation fails, proceed to Step 4.
  1. Ensure that any license numbers or provisioning files necessary for reauthorization are available for use. If Concurrent Use licenses are being used, note the quantity of each license, as well.
  2. From ArcGIS Administrator (or ArcGIS License Server Administrator), select 'Authorization' from the left panel, and click 'Deauthorize'.
  3. When the Software Authorization Wizard opens, select which deauthorization method to use, and click Next.
  4. Under 'Deauthorization Options', ensure all licenses are selected. Click Next.
  5. Once the Software Authorization Wizard has successfully deauthorized the licenses, click Finish to complete the process.
  6. To reauthorize the licenses, select Authorization again from the left panel of ArcGIS Administrator (or ArcGIS License Server Administrator). Under 'Version', select the needed version type, and click 'Authorize Now'.
  7. When the Software Authorization Wizard opens, proceed with the authorization process. Upon successful authorization, the licenses appear under the Availability section of the ArcGIS Administrator (or ArcGIS License Server Administrator).
Related Information
