問題
The ArcGIS Field Maps app allows mobile workers to use the app in the field to collect location and fill out forms. In some instances, a web map containing editable layers and enabled for ArcGIS Field Maps mobile use is not editable in the mobile app. When searching for the web map in the app, it only appears when selecting the 'Read-only' options.
This issue occurs when only the 'Use in ArcGIS Field Maps Mobile' option is enabled, while the 'Use in ArcGIS Collector' option is disabled in the web map settings.
To enable web map editing in ArcGIS Field Maps app, enable the Use in ArcGIS Collector and Use in ArcGIS Field Maps Mobile options.
記事 ID: 000025697
ArcGIS エキスパートのサポートを受ける
今すぐチャットを開始
