HOW TO
The area of a polygon created in ArcGIS Pro can be determined in the attribute table of the polygon in the Shape_Area field. The area of the overlap between two or more polygon layers can also be determined with the Count Overlapping Features tool or the Clip tool. The image below shows three polygon layers overlapping each other, and the area of the overlapping geometry is to be determined.
Use the Count Overlapping Features tool
Use this method to determine the area of multiple polygon overlaps and multiple instances of overlaps.
The image below demonstrates the attribute table of the output overlapping polygon feature displaying the area of all overlaps from three different polygon layers in the Shape_Area field. The field values highlighted in blue represent the area of two different polygon overlaps, and the field value highlighted in red represents the area of three different polygon overlaps.
Use the Clip tool
Alternatively, if only two polygon layers overlap, and an output feature class of the overlapping area is needed, use the Clip tool.
The image below demonstrates the attribute table of the output clip feature layer displaying the area of the overlap of two different polygon layers in the Shape_Area field.
Article ID:000027751
Get help from ArcGIS experts
Download the Esri Support App
