HOW TO
Add a geospatial PDF file to Collector for ArcGIS
Summary
A geospatial PDF file contains spatial attributes such as coordinates, azimuth, and the coordinate system. So, it is possible to use the data to measure distances, track locations, and run geoprocessing operations in a mapping software or application. However, it is not possible to upload a geospatial PDF file directly to Collector for ArcGIS for data collection. The PDF file must be converted into a raster format and published as a tile package before it is used in Collector for ArcGIS.
Procedure
Use the following steps to add a geospatial PDF file to Collector for ArcGIS:
  1. In ArcMap, convert a geospatial PDF file to a GeoTIFF file using the PDF to TIFF tool.
Using the PDF to TIFF tool, a PDF file is converted to a Tagged Image File Format (TIFF) file, while a geospatial PDF file is converted to a GeoTIFF file.
The image below shows a GeoTIFF file of the City of San Antonio converted from a geospatial PDF file using the PDF to TIFF tool.
This is a GeoTIFF file
If the PDF file is a non-geospatial PDF file, georeference the PDF file using either the method described in ArcMap: Georeferencing a raster to a vector or ArcMap: Georeferencing a raster to another raster.
  1. Export the GeoTIFF file as a tile package (.tpk file) to ArcGIS Online using the steps outlined in ArcMap: How to create a tile package. For more information on sharing tile packages, refer to ArcGIS Blog: Using tile packages for publishing hosted tile layers.
  2. In ArcGIS Online, open the item details page and click Publish to publish the tile package as a hosted tile layer.
Only Administrator and Publisher roles have the privileges to publish items in ArcGIS Online.
  1. Add the hosted tile layer to a web map. The image below shows the exported tile package when added to a web map as a layer.
This is the tile package in Map Viewer
  1. Open Collector for ArcGIS and view the web map containing the hosted tile layer.
If the web map does not appear in Collector for ArcGIS, refer to Problem: Unable to view a web map in Collector for ArcGIS and ArcGIS Online: Set map options for apps.
The image below shows the hosted tile layer in Collector for ArcGIS.
Layer appears in Collector for ArcGIS
Article ID:000021054
Software:
  • ArcGIS Online
  • ArcGIS Desktop 1
  • ArcGIS Collector
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
