HOW TO
In ArcGIS Pro, features are symbolized using the default Esri symbol sets. If custom symbology is required, it is possible to import an image as a picture marker symbol under the Style option and use the image as a style in the map.
Note: The image style symbology is only applicable to point feature layers.
The following steps describe how to import an image to ArcGIS Pro as a style.
To apply the new symbol to a layer, in map view, click the layer symbology in the Contents pane to open the Symbology pane. The picture marker symbol created using the above steps is available under the newly created style section.
Article ID: 000019909
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
