PROBLEM
Unable to remove items in ArcGIS Enterprise portal
First Published: September 19, 2024
Last Published: August 4, 2025
Attempts to delete items in ArcGIS Enterprise portal fail, with the following error messages returned in the ArcGIS Server logs:
Error:
Unable to remove <item name>.<item extension> from server directory arcgisuploads. Failed to delete the item '<item ID>'. Configuration store error. File system '\\<ArcGIS Server installation location>\arcgisserver\config-store\uploads\<item ID>.json' remove failed. Delete item failed.
Error:
Failed to delete the item '<item ID>'. Configuration store error. File system '\\<ArcGIS Server installation location>\arcgissserver\config-store\uploads\<item ID>.json' remove failed. Delete item failed.
Error:
com.esri.arcgis.discovery.admin.AdminException: Configuration store error. File system '\\<ArcGIS Server installation location>\arcgisserver\config-store\uploads\<item ID>.json' remove failed. Delete item failed.
Cause
The portal index is corrupted, causing the index count for users to not match the store index count. This results in certain item's becoming detached, preventing them from being deleted.
Solution or Workaround
Perform a full reindex from the ArcGIS Portal Administrator Directory.
  1. Navigate to the Portal Administrator Directory as an administrator using the following URL:
https://<machine_name>.<domain_name>.com/webadaptor/portaladmin
  1. Navigate to System > Indexer > Reindex.
  2. For Mode, select Full from the drop-down list.
  3. For Format, select a response format from the drop-down list.
  4. Click Reindex.
Article ID: 000033526
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
