PROBLEM
When attempting to delete an item in Portal for ArcGIS, the process fails, returning the following error message:
Error: Item does not exist or is inaccessible. Error: 400
This error is returned when attempting to delete a detached item that does not exist in the portal content directory.
When a delete command is executed from Portal for ArcGIS, the item ID in the ArcGIS Portal Directory content store is cross-referenced with the item ID in the portal's internal database. The error occurs when Portal for ArcGIS cannot identify the item in the content directory.
Note: The portal content directory is commonly found at: <Portal for ArcGIS installation directory>\arcgis\arcgisportal\content\items
Note: If the problem persists, reindex Portal for ArcGIS, and delete the item. Refer to ArcGIS REST APIs: Reindex for more information.
Article ID: 000024798
Get help from ArcGIS experts
Start chatting now
