PROBLEM
Unable to configure ArcGIS Web Adaptor (IIS) with ArcGIS Server and Portal for ArcGIS
First Published: October 19, 2023
Last Published: October 19, 2023
Attempts to configure either Portal for ArcGIS, ArcGIS Server, or both with ArcGIS Web Adaptor (IIS) in an ArcGIS Enterprise deployment fail, and one of the following error messages is returned on the Web Adaptor configuration page.
Portal for ArcGIS
Error:
Unable to configure Portal for ArcGIS with the web adaptor. Please make sure that the Portal for ArcGIS machine is running and that the account specified has administrative privileges to the Portal.
The error message returned when configuring ArcGIS Web Adaptor with Portal for ArcGIS
ArcGIS Server
Error:
Unable to configure the ArcGIS Server site with the web adaptor. Please make sure that the machine hosting the site is running and that the account specified has administrative privileges.
The error message returned when configuring ArcGIS Server with ArcGIS Web Adaptor
Cause
The incorrect administrator or primary site administrator credentials are used on the ArcGIS Web Adaptor (IIS) configuration page. Refer to ArcGIS Enterprise: Configure ArcGIS Web Adaptor with Portal for ArcGIS and ArcGIS Enterprise: Configure ArcGIS Web Adaptor with a server site for information regarding the credentials used during the ArcGIS Web Adaptor (IIS) configuration.
Solution or Workaround
On the ArcGIS Web Adaptor (IIS) configuration page, use the correct administrator or primary site administrator credentials to configure either Portal for ArcGIS, ArcGIS Server, or both with ArcGIS Web Adaptor (IIS). If a temporary administrator account is required to configure Portal for ArcGIS with ArcGIS Web Adaptor (IIS), refer to Portal for ArcGIS: Recovering the portal when no administrator accounts are available for instructions. If a credential reset is required for the primary site administrator account, refer to ArcGIS Server: Reset the primary site administrator's password for instructions.
Article ID: 000031384
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
  • ArcGIS Web Adaptor
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
