PROBLEM
When expanding nested widgets in the Sidebar widget in ArcGIS Experience Builder, map elements from the Map widget are visible on the nested widgets. In this example, the map element is the basemap credits, which are visible on the nested widgets within the Sidebar widget, as shown in the map below.
The Overlay setting is enabled in the widget. Expanding the side panel of the Sidebar widget causes map elements from the Map widget to overlap parts of the other panel in the Sidebar widget.
Toggle the Overlay setting off to prevent the side panel from overlapping the other panel when expanded.
The map shows the elements displayed without overlaps in the nested widgets of the Sidebar widget in ArcGIS Experience Builder.
Article ID: 000034086
Get help from ArcGIS experts
Start chatting now
