PROBLEM
When previewing or publishing an experience in ArcGIS Experience Buiilder, a widget's interactive buttons cannot be clicked if a Sidebar widget is placed in front of the buttons. In this example, the interactive map tools in the Map widget is visible but cannot be clicked when the empty panel of the Sidebar widget is placed over the tools as demonstrated in the image below.
The Sidebar widget takes up a fixed amount of space in the experience, which can overlap with other widgets. This prevents interactions with any widgets behind the Sidebar widget, regardless if it is minimized or not.
Instead of placing the Sidebar widget in front of the Map widget, place the Map widget in one of the panels of the Sidebar widget.
The image below demonstrates the tools in the Map widget can be interacted when it is placed in the Sidebar widget when the experience is previewed or published.
Article ID:000030104
Get help from ArcGIS experts
Download the Esri Support App
