PROBLEM
In ArcGIS Online Map Viewer, labels are used to convey information about features. Refer to ArcGIS Online: Configure labels (Map Viewer) for more information. When features are in close proximity, labels are hidden by default, even when zoomed to the maximum extent and after adjusting label placement. The web map below shows an example where the Point D label is hidden as it is located near Point C.
This is expected behavior in ArcGIS Online Map Viewer. Labels for nearby features are hidden and displayed differently due to compatibility issues with label placement properties.
Use one of the following options to display hidden labels on a web map in ArcGIS Online Map Viewer:
The image below shows the newly created sketch feature displayed as the label on the web map in ArcGIS Online Map Viewer.
Note: This workflow consumes credits depending on the number of tiles generated. Refer to ArcGIS Online: Understand credits for more information.
Convert the label to annotation using the Convert Labels To Annotation tool in ArcGIS Pro and publish the layer as a hosted tile layer to ArcGIS Online. Refer to the second workaround in Problem: Label placement properties in ArcGIS Pro are not retained in ArcGIS Online Map Viewer for instructions. In Step 4, before publishing the annotation layer as a tile layer, in the Share As Web Layer pane, on the Configuration tab, under the Tiling Scheme section, drag the slider for Levels of Detail to set the map scales for the tiles.
Note: In ArcGIS Pro 3.4, in the Share As Web Layer pane, on the Configuration tab, expand Options and click Cache locally before publishing the layer as a tile layer.
The image below shows the annotation tile layer displaying the label on the web map in ArcGIS Online Map Viewer.
Article ID: 000034343
Get help from ArcGIS experts
Start chatting now
