PROBLEM
Coded value domains published from a zipped file geodatabase are not preserved in Collector for ArcGIS
Last Published: July 28, 2025
In some instances, when working in Collector for ArcGIS using a hosted feature layer published from a zipped file geodatabase, the coded value domains of the feature layer are not preserved and the domains are not listed in the attribute field.
The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
Cause
This is by design. Publishing a hosted feature layer from a zipped file geodatabase does not preserve the domains because when the feature layer is published, the domains remain in the file geodatabase and are not accessible from the hosted feature layer. For more information on publishing a hosted feature layer from a file geodatabase, refer to ArcGIS Online: Publish the contents of a file geodatabase.
Solution or Workaround
To resolve this issue, publish the feature layer containing the coded value domains as a service directly from ArcMap to ArcGIS Online. Once the hosted feature layer is published in ArcGIS Online, create and share the web map for data collection in Collector for ArcGIS.
The following image shows the preserved coded value domains in a hosted feature layer that is published directly from ArcMap in Collector for ArcGIS.
Coded values domain preserved in Collector for ArcGIS
The issue of domains not appearing in Collector for ArcGIS can be due to several reasons. Some of them are found in the technical article, Problem: Domains do not appear in Collector for ArcGIS after a hosted feature service is modified in ArcGIS Online where the article highlights that the domains are not preserved after modifying the hosted feature service in ArcGIS Online.
Article ID: 000018654
Software:
  • ArcGIS Collector
  • ArcMap
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
