PROBLEM
ArcGIS Pro: Unable to publish hosted layers to the ArcGIS Enterprise portal
Last Published: March 25, 2025
In ArcGIS Pro, attempting to publish hosted layers to a federated ArcGIS Enterprise portal fails and returns the generic error message below.
Error:
Failed to publish web layer
The error message in the ArcGIS Enterprise portal
Cause
  • The federated server is not configured as a hosting server in the ArcGIS Enterprise portal. Configuring a hosting server is required to publish hosted layers. Refer to Portal for ArcGIS: Prerequisites to publish hosted layers for more information.
  • The data stores are not validated in ArcGIS Server Manager.
  • The ArcGIS Server or ArcGIS Data Store service is not running.
Solution or Workaround
Configure the hosting server
In the ArcGIS Enterprise portal, configure the federated server as a hosting server. Refer to Portal for ArcGIS: Specify the hosting server for instructions.
Validate the data stores in ArcGIS Server Manager
In ArcGIS Server Manager, validate the registered data stores to ensure the connection is established. Refer to ArcGIS Server: Validate data stores for instructions.
Restart the ArcGIS Server or ArcGIS Data Store service
On the ArcGIS Server or ArcGIS Data Store machine, restart the service.
  1. On the machine, search for and select Services in the search bar.
  2. In the Services window, right-click the ArcGIS Server or ArcGIS Data Store service and select Restart if the service is already running. If not, select Start.
Article ID: 000035104
Software:
  • ArcGIS Data Store
  • ArcGIS Pro
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
