HOW TO
Move ArcGIS Insights Desktop to a new computer
Last Published: October 29, 2024
Summary
There are times when it may be necessary to move ArcGIS Insights Desktop to a new computer. You could export every single workbook to the new computer, but you might lose local content. The following steps provide an alternate way to do this.
Procedure
The below steps have not yet been formally tested and are not documented, therefore this procedure is not officially supported. For example, there may be an issue if the username on both machines is not exactly the same. Also, moving from macOS to Windows, and vice versa would not work.
  1. Make sure that Insights is not open or actively running on the 'old' machine.
  2. Install Insights on the 'new' machine, but don't start it. If Insights is already started on the new machine, delete the following folder:
%APPDATA%\Esri\ArcGIS Insights
  1. Copy the folder '%APPDATA%\Esri\ArcGIS Insights' from the old machine to the new machine.
  2. Start Insights on the new machine.
Article ID: 000027165
Software:
  • ArcGIS Insights
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
