HOW TO
Select the correct geographic (datum) transformation when projecting between datums
Summary
It is necessary to specify a geographic (datum) transformation when using the ArcToolbox Project Wizard (ArcGIS version 8.x) or Project tool (ArcGIS versions 9.x, 10.x) to project shapefiles or geodatabase feature classes between different geographic coordinate systems (datums).
The user must also select an appropriate Geographic (datum) transformation in ArcMap when displaying data that are projected on different datums. For more information on selecting an appropriate Geographic transformation, refer to ArcGIS Help: Choosing an appropriate transformation.
Procedure
Click a link in the Related Information section to access a list of the geographic (datum) transformation methods available in ArcGIS, and the geographic areas for which these transformations are appropriate for the version of ArcGIS Desktop used.
Datum transformations work in either direction. For example, the transformation listed as NAD_1927_to_NAD_1983_NADCON transforms from NAD 1983 to NAD 1927, as well as from NAD 1927 to NAD 1983.
Article ID: 000004829
Software:
  • ArcMap
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
