HOW TO
In ArcGIS QuickCapture, the default organization basemap discards locally recorded data on the mobile app after submission to optimize performance and prevent data redundancy. However, in certain scenarios, configuring a web map to retain access to recently recorded features after syncing is preferred, as it reduces uncertainty and improves data accuracy. This article provides the workflows for configuring a custom web map to retain records on the map after syncing in ArcGIS QuickCapture.
The image below shows the default basemap in the ArcGIS QuickCapture mobile app displaying no recently recorded features after the records are sent.
Note: An active internet connection is required to retain the newly recorded features using a custom web map in the ArcGIS QuickCapture mobile app. When offline, the app displays features within the current map extent, but these features may not persist if the map is closed or the app is relaunched.
The image below shows the newly added features visualized on the map in the ArcGIS QuickCapture mobile app after syncing the records to the web map in ArcGIS Online.
Article ID: 000034320
Get help from ArcGIS experts
Start chatting now
