HOW TO
Resize the width of the elements in a row to the same size in ArcGIS Dashboards Classic
First Published: August 31, 2021
Last Published: April 5, 2022
Summary
In ArcGIS Dashboards, elements docked in the same row can be resized to the same width using the 'Distribute width evenly' function. An element can also be resized individually by dragging the vertical or horizontal border using the percentage displayed as a guide. Refer to ArcGIS Dashboards: Resize elements for more information. However, these features are unavailable in ArcGIS Dashboards Classic.
The image shows that dashboard elements are docked in two rows. This article provides the workflow to resize the elements in Row 1 to the same width in ArcGIS Dashboards Classic using ArcGIS Online Assistant.
A dashboard layout with two rows of elements. There are four elements in the upper row and two in the lower row.
ArcGIS Online Assistant is not supported by Esri Support Services. Errors when editing the JSON of an application can irrevocably break the application. It is imperative to create a backup copy of the JSON before editing.
Procedure
  1. Log in to ArcGIS Online Assistant using an ArcGIS Online credential.
  2. On the ribbon, click I want to..., and select View an Item's JSON.
The drop-down menu after clicking the I want to… button on the ArcGIS Online Assistant header.
  1. Copy and paste the item ID of the dashboard to the Search My Content search bar, and press Enter on the keyboard.
The item ID of a dashboard is at the end of the dashboard URL. Refer to ArcGIS Dashboards: Dashboard URLs for more information.
  1. Click the dashboard item under Search Results.
A result is displayed under Search Results. The result is in a light-blue box.
  1. Navigate to the Data box on the right panel, and click the Edit JSON pencil icon on the header.
The header of the Data box. The Edit JSON button is the third from the left and is represented with a pencil icon.
  1. Resize the width of the elements in a row to the same size.
    1. Navigate to the "elements" nested arrays under "layout". Elements docked in the same row are listed in the same nested array, surrounded by a pair of square brackets, [ ]. The width of the elements can be modified by changing the values of the "width" keys. The image shows the two rows of elements grouped in separate nested arrays.
The Data box with editing enabled. The dashboard elements are grouped according to the respective row.
  1. Change the values of the "width" keys. The width of an element is the percentage of the element's width in relation to the whole dashboard's width. The "width" value is presented in the decimal form of a percentage, and the "width" values of the elements in the same row add up to '1'. In this example, to resize the width of the four elements in Row 1 to the same size, the "width" values are modified to '0.25'.
The width values of the elements in the same row are edited to 0.25.
  1. Additionally, the height of the rows can be adjusted by modifying the "height" values. To achieve the best result, it is recommended to adjust the height of the row instead of the individual elements. The "height" key of a row is located after the square brackets surrounding the individual elements in the row. Similar to the "width" values, the "height" values of the two rows add up to '1'. In this example, the "height" values of Row 1 and Row 2 are both '0.5'.
The height keys of the rows are located after the nested array square brackets. The values are both 0.5
  1. Click the floppy disk icon on the Data box header to save the modifications.
The header of the Data box. The save button is in the middle of the buttons and is represented with a floppy disk icon.
  1. Refresh the dashboard. The elements in Row 1 are resized to the same width.
The image shows a dashboard layout with two rows of elements. The width of the elements are distributed equally across the upper row.
Article ID: 000026337
Software:
  • Third Party Product
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
