HOW TO
Permanently reorder fields in a feature class using the Feature Class to Feature Class tool in ArcMap
First Published: December 3, 2020
Last Published: June 23, 2025
Summary
In ArcMap, it is possible to reorder attribute table fields in a current map. Refer to ArcMap: Rearranging the columns in a table for more information. However, the order of the fields cannot be changed at the database level.
ArcMap is in Mature support and will be retired March 1, 2026. There are no plans for future releases of ArcMap, and it is recommended that you migrate to ArcGIS Pro. See Migrate from ArcMap to ArcGIS Pro for more information.
The image below shows the attribute table fields order of the ‘FL_Hospitals’ feature class.
Image showing the field order in the FL_Hospitals feature class in ArcMap.
In some instances, it is necessary to permanently reorder the fields in a feature class. Use the Feature Class to Feature Class tool to write the features from the existing feature class to a new feature class, and reorder the fields in the ‘Field Map (optional)’ section.
The order of the OBJECTID and Shape fields cannot be changed.
Procedure
The Feature Class To Feature Class tool has been deprecated in ArcGIS Pro and replaced by the Export Features (Conversion) tool.
Warning:
The workaround provided does not preserve any existing relationship classes in the output feature class containing the reordered fields. Esri recommends copying the dataset to a new geodatabase, and using the new geodatabase before reordering fields so that changes made are not applied to the original geodatabase.
  1. In ArcMap, click the Search Image of the Search button. button on the Standard toolbar.
  2. In the Search window, search for and select the Feature Class to Feature Class (Conversion) tool.
  3. Complete the information in the Feature Class to Feature Class dialog box, and run the tool.
    1. Select the existing feature class under Input Features.
    2. Specify an Output Location for the new feature class.
    3. Under Output Feature Class, enter the name of the new feature class.
    4. Under Field Map (optional), reorder the fields by selecting the field name, and clicking the up or down arrow button.
    5. Click OK to run the tool.
Image showing the steps to fill up the required information in the Feature Class to Feature Class dialox box to run the tool.
A new feature class is created and added to the map. The image below shows the rearranged field order in the new feature class, FL_Hospitals2.
Image showing the order of the fields in the new feature class.
Article ID: 000024554
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
