HOW TO
Midpoints are supporting geometries used in linear features, often derived using manual measurement or digital processing. Real-world examples of accurate positioning using midpoint coordinates include identifying potential inspection or sensor points along pipelines in utility management and segmenting rivers for sampling site selection during environmental assessments.
In ArcGIS Pro, midpoints of line features can be identified using geoprocessing tools. However, when midpoints are derived from polygons, some additional processing is necessary. This article provides the workflow to generate and calculate the midpoint coordinates of polygon edges. The following polygon features are used to demonstrate the workflow.
Note: This tool requires an ArcGIS Pro Advanced license.
The line feature layer is added to the Contents pane and displayed on the map.
Note: If calculating only certain polygon edges, use the Select Layer By Attribute tool to select the polygons. Ensure the Use the Selected records:<record count> option is toggled on when running the Feature Vertices To Points tool. Refer to ArcGIS Pro: Select features using attributes for instructions.
.The midpoint feature layer is added to the Contents pane and displayed on the map.
The coordinate fields with the calculated values are added to the midpoint feature layer.
Article ID: 000036287
Get help from ArcGIS experts
Start chatting now
