HOW TO
Calculate XY values using Arcade in ArcGIS Pro
First Published: July 26, 2022
Last Published: June 20, 2023
Summary
In ArcGIS Pro, spatial and location information of point features can be added to the attribute table and this task can be automated using Arcade. The workflow provided in this article describes how to calculate the XY values of point features using an Arcade expression.
Procedure
  1. Open the ArcGIS Pro project.
  2. Add a new field to the feature class in ArcGIS Pro for the x-value.
    1. In the Contents pane, right-click the layer and click Attribute Table.
    2. In the attribute table, click Add Field The Add Field icon..
    3. In the Fields view, specify a name for the field in the Field Name column.
    4. Double-click the Alias column of the field and specify an alias for it.
    5. Double-click the Data Type column of the field and select Long from the drop-down menu.
The Field name, Alias, and Data Type field in the attribute table.
  1. On the top ribbon, on the Fields tab, click Save.
The Save option in the Changes group.
  1. Follow Step 2 to add a new field to the class for the y-value.
<Null> results in the X and Y-values column.
  1. Calculate the x-value field.
    1. In the table view, right-click the x-value field header and select Calculate Field.
    2. In the Calculate Field window, select Arcade from the Expression Type drop-down menu.
    3. Type the following expression and click Verify.
Round(Geometry($feature).X, 6)
The x-value expression configured.
  1. When the message, “Expression is valid” is returned, click OK.
The
  1. Calculate the y-value field.
    1. In the table view, right-click the field’s header for the y-value and select Calculate Field.
Round(Geometry($feature).Y, 6)
The y-value expression configured.
The image shows the attribute table with the XY values in meter.
The results of the XY values in the attribute table.
Optionally, calculate the XY values in decimal degrees.
    5. Double-click the Data Type column of the field and select Double from the drop-down menu.
The Field Name, Alias, and Data type in the attribute table.
  2. Calculate the x-value field.
//To populate X coordinate in decimal
function MetersToLon(x) {
    var originShift = 2.0 * PI * 6378137.0 / 2.0;
    var lon = (x / originShift) * 180.0;
    return Round(lon, 3);
return MetersToLon(Round(Geometry($feature).X, 6));
The x-value expression is configured in the expression box.
    1. In the table view, right-click the y-value field header and select Calculate Field.
//To populate Y coordinate in decimal:
function MetersToLat(y) {
    var lat = (y / originShift) * 180.0;
    lat = 180.0 / PI * (2.0 * Atan( Exp( lat * PI / 180.0)) - PI / 2.0);
    return Round(lat,3);
return MetersToLat(Round(Geometry($feature).Y, 6));
The y-value expression is configured in the expression box.
The image below shows the attribute table with the calculated XY values in decimal degrees in ArcGIS Pro.
The calculated XY values in decimal degrees.
Article ID: 000028012
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
