HOW TO
The Smart Editor widget in ArcGIS Web AppBuilder allows editing features and related records. It allows creating new features, edit existing features and their attributes. This widget can also be configured to allow creating new feature(s) from existing feature(s).
If the feature being copied has a field that already exists in the target layer, there is the option to keep the default values in the target field or overwrite them with the existing values from the copied feature.
Before beginning, it is necessary to configure the Smart Editor widget. On the General Settings tab, under Copy and Append Features, enable the option to Allow creating new feature(s) from existing feature(s). By default, this setting allows copying features from one layer to another layer with the same geometry type (point, polygon, or line). Additionally, there are the options to Allow copy polygon to point and/or Allow copy line to point.
When copying a polygon to a point, a centroid point is generated and added to the point layer. When using copy line to point option, specify whether to add the point to the start or the end of the line. These options are shown in the image below.
To copy a feature from one layer to another as a new feature
Copy a polygon as a point to a point layer
These same steps can be applied to copying a line to a point layer.
Article ID: 000027246
Get help from ArcGIS experts
Start chatting now
