HOW TO
Concatenate fields in a table in ArcMap
First Published: May 5, 2016
Summary
In some instances, it is useful to combine two or more fields and display the combined field attributes in a new field in ArcMap.
Procedure
The instructions provided describe how to concatenate attributes from two or more fields in a table using ArcMap. In this example, the address, city, and state fields are concatenated into a new field to display full addresses.
  1. In ArcMap, click the Editor drop-down menu on the Editor toolbar, and select Start Editing.
  2. In the Table Of Contents, right-click the selected layer or stand-alone table, and select the Open Attribute Table or Open option, depending on the data source.
  3. Select Table Options > Add Field.
It is possible to use an existing field, but the output of this process overwrites the existing data in the field.
The Add Field option.
  1. In the Add Field dialog box, define the new field name and type, and click OK.
To concatenate string fields, select text field data type. Select short or long integer field data type for number fields. Refer to: ArcGIS field data types for more information on the field data types.
The Add Field dialog box.
  1. Right-click the new field name in the attribute table, and select Field Calculator.
Opening the Field Calculator for the new field.
  1. Type the following expression, and replace [Field Name] with the name of each individual field to be concatenated from the Fields list:
Code:
[Field Name] & " " & [Field Name] & " " & [Field Name]
The double quotation marks (" ") add a space between the values that are being concatenated. Remove (" ") to eliminate the space between the field names.
The Field Calculator.
  1. Click OK. The fields are combined and displayed in the new field.
The concatenated fields in the attribute table.
Article ID: 000005365
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
