Summary
In ArcGIS Pro, calculating the area percentage and feature count of joined polygon features within buffer zones is a spatial analysis technique for understanding the spatial distribution of features relative to a central location. Quantifying the spatial distribution of features across distance zones provides valuable insights for making location-based decisions. This article describes the workflow to calculate the area percentage and count of joined features within buffer zones in ArcGIS Pro.
Procedure
- Open the ArcGIS Pro project with two polygon feature layers. In this example, the polygon feature layers are Polygon1 and Polygon2.
- Join the two polygon feature layers based on the common field using the Add Join tool.
- On the Analysis tab, in the Geoprocessing group, click Tools.
- In the Geoprocessing pane, search for and select Add Join (Data Management Tools).
- In the Add Join pane, select the feature layer for the Input Table drop-down list. In this example, Polygon1 is selected.
- For Input Field, select the preferred field of the input layer. In this example, OBJECTID is selected.
- For Join Table, select the feature layer to be joined. In this example, Polygon2 is selected.
- For Join Field, select the preferred field of the join layer. In this example, OBJECTID is selected.
- For Join Operation, select Join one to many.
- Click Run.
Run the Select Layer By Attribute tool if exporting only selected features.
- Run the Export Features tool to export the joined feature layer.
- Select a preferred polygon feature on the map to be buffered. Refer to ArcGIS Pro: Select features for instructions.
- Run the Multiple Ring Buffer tool to create zone ranges for a selected polygon feature in the joined feature layer.
- In the Geoprocessing pane, search for and select Multiple Ring Buffer (Analysis Tools).
- In the Multiple Ring Buffer pane, for Input Features, select the output feature layer from Step 3.
- For Output Feature class, specify a name and location.
- For Distances, specify the buffer distances. In this example, the distance is 50.
- Click Add another to add another buffer distance if necessary. In this example, 100 and 150 are added.
- For Distance Unit, select the buffer linear unit. In this example, Meters is selected.
- Click Run.
- Summarize the number of polygons within the buffer zones using theĀ Summarize Within tool.
- In the Geoprocessing pane, search for and select Summarize Within (Analysis Tools).
- In the Summarize Within pane, for Input Polygons, select the output feature layer from Step 5.
- For Input Summary Features, select the joined feature layer. In this example, Polygon1_ExportFeatures is selected.
- Disable the Use the selected records option if necessary.
- For Output Feature Class, specify a name and location.
- For Shape Unit, specify the unit to calculate the shape summary attributes. In this example, Square meters is selected.
- Click Run.
- Calculate the area and percentage of the joined features within the buffer zones using the Tabulate Intersection tool. Refer to How To: Calculate the percentage of intersecting polygon areas in ArcGIS Pro for instructions. For Zone Fields, select the Shape_Area, distance, and 'Count of Polygons' fields.
The attribute table below shows the counts and area percentages of the joined features within the buffer zones.
