HOW TO
Calculate the percentage of a field value from a specified field in ArcGIS Pro
Last Published: March 3, 2023
Summary
In ArcGIS Pro, Python expressions can be used to calculate the percentage of a field value from a specified field. This article provides an example and instructions using Python expressions to calculate the percentage of the population for each district in Hong Kong and create a new field in ArcGIS Pro.
The image below shows the PopDis2021 attribute table of the population for each district in Hong Kong.
The PopDist2021 attribute table
Procedure
  1. In the Contents pane, right-click the feature class and click Attribute Table to open the attribute table of the feature class.
Opening the attribute table of the feature class from the Contents pane
  1. Click Calculate to open the Calculate Field tool.
Refer to ArcGIS Pro: Calculate Field (Data Management) for more information on the parameters in the Calculate Field tool.
  1. In the Calculate Field dialog box, configure the following parameters:
    1. For Input Table, select the feature class.
    2. For Field Name (Existing or New), select the field to be edited or create a new field. In this example, the 'Percentage' field is created.
    3. For Field Type, select an integer field type. In this example, 'Double (64-bit floating point)' is selected.
    4. For Expression Type, select Python 3.
    5. Specify the following expression in the first code block. In this example, '<fieldName1>' is named as Number_of_Persons.
update(!<fieldName1>!)
  1. Specify the following Python expression in Code Block:
    1. Define the update() method. In this example, '<varName>' is named as numbPersons.
def update(<varName>):
The following procedure must all be within the same indented code block. Refer to the full script sample for clarification.
  1. Import the ArcPy module and create an empty array parameter.
     import arcpy
     list = []
  1. Create a loop to run the SearchCursor() function to insert all field into the array parameter in Step 3(f)(ii).
    with arcpy.da.SearchCursor(r"<featureClassPath>", ["<fieldName1>"]) as cursor:
        for row in cursor:
            list.append(row[0])
  1. Calculate the sum of the value. In this example, '<varName1>' is named as S.
    <varName1> = sum(list)
  1. Specify the following statement to return the percentage of the field value.
    return <varname> / <varname1> * 100
The code block below is an example of the full expression.
def update(numbPersons):
    import arcpy
    list = []
    with arcpy.da.SearchCursor(r"C:\Users\ISC-Testing\Documents\29398 calculate percentage\29398 calculate percentage.gdb\PopDist2021", ["Number_of_Persons"]) as cursor:
        for row in cursor:
            list.append(row[0])
    S = sum(list)
    return numbPersons / S * 100
  1. Click Verify to run a test of the expression. If the expression is valid, click OK.
The Calculate Field tool pane with the parameters to be filled
The image below shows the 'Percentage' field added to the 'PopDist2021' attribute table.
The PopDist2021 attribute table with the Percentage field added
Article ID: 000029398
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
