HOW TO
This article outlines the process to apply an ArcGIS Enterprise license to an existing ArcGIS Enterprise Workgroup deployment, without needing to reinstall ArcGIS Enterprise, or any of its underlying components.
ArcGIS Enterprise Workgroup will be phased out alongside ArcGIS Desktop, with ArcGIS Enterprise 11.1 being the last version to support ArcGIS Enterprise Workgroup licensing.
ArcGIS Enterprise Workgroup was sold as a lightweight version of ArcGIS Enterprise with certain limitations on the number of users and compute capacity. Over time, the majority of users have migrated these use cases to ArcGIS Online or ArcGIS Enterprise. With Online or Enterprise, users can work with larger amounts of data and reach broader audiences of their colleagues. This article explains how you too can undertake this upgrade to ArcGIS Enterprise.
ArcGIS Enterprise Workgroup and ArcGIS Enterprise rely on the same installation files. This means that users do not need to uninstall existing installations of ArcGIS Enterprise Workgroup to upgrade to ArcGIS Enterprise.
You will need your license files before getting started. Remember, ArcGIS Enterprise license files are version specific, so make sure to generate the license file for the version that matches your installation. For help on generating license files, see this documentation: Obtaining an authorization file (ArcGIS Server), Obtain a portal license file (Portal for ArcGIS). Once users obtain a new ArcGIS Server and Portal for ArcGIS License, they should follow this workflow:
ArcGIS Server:
Portal for ArcGIS
Portal for ArcGIS does not need new license files to upgrade from ArcGIS Enterprise Workgroup and will function at its full capacity using the existing license files. However, administrators should edit their existing Portal license files via My Esri to take advantage of the additional users available as part of the upgrade. See this Knowledgebase article for instructions on editing existing Portal license files to add additional licenses: How To: Edit License Files in My Esri for Portal for ArcGIS 10.7 and later versions
ArcGIS Data Store
Once these procedures are completed, also run the updatelicense utility, as shown in the image below, on all associated instances of ArcGIS Data Store to ensure that the most up to date license is being used. This applies for ArcGIS Enterprise 10.9.1 and earlier versions.
Once the above has been completed, the upgrade to ArcGIS Enterprise is complete. You have two options to migrate workgroup geodatabases to an enterprise geodatabase:
Article ID: 000028255
Get help from ArcGIS experts
Download the Esri Support App
