Frequently asked question
Mosaic datasets created in ArcGIS Pro are compatible with concurrent and subsequent versions of ArcGIS software, but mosaic datasets created with newer versions of ArcGIS Pro cannot be read and handled with older versions of other ArcGIS software.
Note: For example, mosaic datasets created in ArcGIS Pro 2.3 cannot be used with previous versions of ArcGIS such as ArcGIS Pro 2.2, ArcMap 10.6.1, or ArcGIS Server 10.6.1, but are compatible with ArcGIS 10.7 or ArcGIS 10.7.1, including ArcGIS Enterprise, ArcGIS Server, and ArcMap.
Esri recommends creating and editing mosaic datasets in the ArcGIS Pro version compatible with the other versions of ArcGIS software. The table below lists the product version compatibility of the mosaic dataset created in ArcGIS Pro and other ArcGIS software.
ArcGIS Pro Version
| ArcGIS Enterprise, ArcGIS Server, and ArcMap Version |
| 2.6 | 10.8.1 |
| 2.5 | 10.8 |
| 2.4 | 10.7.1 |
| 2.3 | 10.7 |
| 2.2 | 10.6.1 |
| 2.1 | 10.6 |
| 2.0 | 10.5.1 |
| 1.4 | 10.5 |
| 1.3 | 10.4.1 |
| 1.2 | 10.4 |
| 1.1 | 10.3.1 |
| 1.0 | 10.3 |
Alternatively, upgrade the mosaic dataset version created in an older version of ArcGIS Pro by editing it using a newer version of ArcGIS Pro.
Note: For example, if a mosaic dataset is created using ArcGIS Pro 2.3, editing it using ArcGIS Pro 2.5 upgrades the version of the mosaic dataset. This mosaic dataset is compatible with ArcGIS 10.8 or ArcGIS 10.8.1. including ArcGIS Enterprise, ArcGIS Server, and ArcMap.
Article ID: 000020432
Get help from ArcGIS experts
Start chatting now
