ERROR
In ArcGIS Online, when attempting to change the ownership of a group to a member in an organization, the following error message is returned:
Error: Unable to reassign the group at this time.
The following are known causes for this issue:
Depending on the cause, use one of the options below to resolve the issue.
Note: Only an organization's administrator can perform the following workflows.
Update the member’s role to enable the privilege to own a group
Note: A role defines the set of privileges assigned to a member. Privileges are assigned to members through a default role or a custom role.
Rename the new group or the existing group
Rename the new group before changing the group ownership to the member, or rename the existing group owned by the member.
to rename it. Refer to ArcGIS Online: Edit group properties and settings for more information. Note: Alternatively, delete the existing group, and change the ownership of the new group to the member.
Delete the group and create a new group without update capabilities for a non-administrator member
Note: If delete protection is enabled, refer to ArcGIS Online: Delete your group to delete the group.
Note: Alternatively, change the member’s default role to Administrator, and change the ownership of the group with update capabilities to the member. Refer to ArcGIS Online: Change member roles for more information.
Article ID: 000023476
Get help from ArcGIS experts
Start chatting now
