ERROR
Invalid raster dataset. Failed to create raster layer
First Published: May 5, 2016
Last Published: July 13, 2026
Error Message
The content in this article pertains to ArcGIS versions 8.x and 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
The following error displays when adding an ArcMap exported PNG as a picture to ArcMap:
Invalid raster dataset. Failed to create raster layer.
Cause
This is a known issue with the ArcMap PNG exporter. PNG images over a certain size are corrupted.
Solution or Workaround
Select one of the following options below:
  • Use a different export format.
  • Decrease the size of the map and/or the output resolution.
Article ID: 000008818
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
