PROBLEM
Cannot edit the feature dataset on SDE after canceling the build of a geometric network
First Published: May 5, 2016
After canceling the build of a geometric network, the lock is persisted on the feature dataset. Editing or adding feature classes to the dataset in not allowed. This only occurs in an SDE geodatabase.
Solution or Workaround
Close the current session of ArcCatalog and start another session.
Article ID: 000003432
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
