HOW TO
To make ArcMap and ArcGIS Engine licenses available for use on other machines, such as when moving to a new computer, it is necessary to deauthorize them first.
Note: Deauthorizing licenses using the online method requires access to the Internet.
Deauthorizing Concurrent Use and Single Use licenses essentially use the same workflow. The main difference is where the Software Authorization Wizard is accessed, which is used to perform the deauthorization. Concurrent Use licenses use ArcGIS License Manager, whereas Single Use licenses can be managed via ArcGIS Administrator.
Note: If the license(s) can no longer be accessed for deauthorization (due to a system failure, system loss or destruction or the number of deauthorizations allowed within a year has been exceeded), follow the steps in How To: Recover lost licenses from My Esri instead.
Deauthorize Concurrent Use licenses
Note: When deauthorizing Concurrent Use licenses, the quantity of each license to remove can be changed by entering the appropriate value under the No. of Licenses column.
Deauthorize Single Use licenses
Note: Although the licenses are immediately available for use, the availability may not be immediately displayed on My Esri.
Article ID: 000012548
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
