问题
问题:当安装后配置程序的默认端口从 Mongo 端口修改为其他端口时,Config.db 不更新
Last Published: April 29, 2024
描述
When the default MongoDB port 27017 is changed in the ArcGIS Monitor post-installer, only one of three entries in config.db is updated. As a result, the ArcGIS Monitor Server service stops running.
原因
A connection is not possible due to mismatching port entries.
解决方案或解决方法
Follow the instructions provided to fix this issue.
  1. Start ArcGIS Monitor Administrator.
  2. Navigate to File > Open, and select the config.db file.
  3. On the Mongo tab, update the Mongo Port number to the desired port.
User-added image
  1. Click File > Save.
  2. Restart the ArcGIS Monitor Server service.
文章 ID: 000017589
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
