操作方法
操作方法:与非 Site Scan for ArcGIS 用户共享测量值
Last Published: September 1, 2023
摘要
Site Scan Manager for ArcGIS enables sharing custom analysis displays with members external to the project. It is possible to choose the view receivers can see from the many features inside the analysis panel, such as layers, files and measures.
过程
  1. Navigate to the flight where the measurement is saved.
Image showing measurement saved
  1. Locate the measurement and toggle the button to turn it on.
Image showing measurement toggle
  1. Repeat the previous step with all the measurements to share.
Image showing measurement to share
Any other feature turned on in the layers or files tabs is displayed in the receiver's view (including the orthomosaic). To avoid this, turn off all other features not meant for sharing.
  1. Once finished, click the share icon located at the bottom of the main panel.
Image showing share icon
  1. A link is generated. Use this link to share the measurements and other enabled layers or files.
Consider the following when using this functionality:
  • The receiver of the link cannot modify the measurements
  • All the measurements, layers, and files that are shared can be turned on and off by the receiver, but this is not reflected in the project.
文章 ID: 000023238
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
