操作方法
操作方法:通过 Python 使用当前日期来填充日期字段
Last Published: July 20, 2023
摘要
In ArcGIS Desktop, a date field can be populated with the current date using the Field Calculator in ArcMap or the Calculate function in ArcGIS Pro. The Python parser in the field calculator provides the time.strftime('%d/%m/%Y') function to do so. Alternatively, the current date can also be populated using the UpdateCursor() function.
过程
The following steps describe how to populate a field with the current date using a Python script.
  1. Import the necessary modules.
import arcpy, datetime
  1. Specify the location of the geodatabase and the desired field.
fc = r'C:\Test\Test1.gdb\Feature_1'
field = "Date_Field"
  1. Start a loop with the UpdateCursor() function to populate the selected field with the current date.
with arcpy.da.UpdateCursor(fc, [field]) as rows:
    for row in rows:
        rows.updateRow([datetime.date.today()])
The following shows the full script:
fc = r'C:\UsersUSER1\Desktop\Data\Database1.gdb\Sample'
    for row in rows:
文章 ID: 000023088
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
