操作方法
在 ArcGIS Enterprise 中配置实用程序服务以允许各种任务,例如地理编码和打印资源。 在某些情况下,离线打包服务会损坏或者需要移至其他文件夹。 必须删除离线打包服务并将其重新发布到 ArcGIS Server,才能继续按预期工作。 本文提供了删除并重新发布 ArcGIS Server OfflinePackaging 服务的工作流。
"serviceName": "OfflinePackaging",
"type": "GPServer",
"description": "The OfflinePackaging service is used to create and setup map areas. Map areas make it easier and faster for your users to work offline, by packaging up your map for a specific area ahead of time.",
"capabilities": "null",
"provider": "ArcObjects11",
"clusterName": "default",
"minInstancesPerNode": 0,
"maxInstancesPerNode": 2,
"instancesPerContainer": 1,
"maxWaitTime": 600,
"maxStartupTime": 300,
"maxIdleTime": 1800,
"maxUsageTime": 30000,
"loadBalancing": "ROUND_ROBIN",
"isolationLevel": "HIGH",
"configuredState": "STOPPED",
"recycleInterval": 24,
"recycleStartTime": "00:00",
"keepAliveInterval": -1,
"private": false,
"isDefault": true,
"maxUploadFileSize": 0,
"allowedUploadFileTypes": "",
"properties": {
"virtualOutputDir": "/rest/directories/arcgisoutput",
"maximumRecords": "1000",
"outputDir": "C:\\arcgisserver\\directories\\arcgisoutput",
"jobsDirectory": "C:\\arcgisserver\\directories\\arcgisjobs",
"showMessages": "Info",
"executionType": "Asynchronous",
"toolbox": "${AGSSERVER}/framework/runtime/ArcGIS/Resources/ArcToolBox/Services/OfflinePackaging.tbx",
"jobsVirtualDirectory": "/rest/directories/arcgisjobs"
"portalProperties": {
"isHosted": false,
"portalItems": [{
"itemID": "6d70b8fb270b46a9b1c84fe93c041b75",
"type": "GPServer"
"extensions": [],
"frameworkProperties": {},
"datasets": []
执行上述工作流后,服务和门户项目可能不同步,由此导致出现以下错误:
如果发生任何错误,请在 Portal for ArcGIS 中标识 OfflinePackaging 项目的 itemID 并更新该 itemID。
Note: When performing Step 11, the JSON should be configured with the correct itemID. This item can be found by searching for "offlinepackaging" in Portal for ArcGIS.
文章 ID: 000031427
获取来自 ArcGIS 专家的帮助
立即开始聊天
