ERROR
When attempting to delete an ArcGIS Server service, the process fails and returns an error message.
Error: Service 'System/<service_name>.gpserver' is required and cannot be deleted.
The 'isDefault' parameter in the Service Properties JSON is set to true. If the value is set to true, the service is considered as the main system service and cannot be deleted as it is required to ensure ArcGIS Server is running properly.
Article ID: 000028339
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
