操作方法
方法:将选定要素转换为 ArcMap 中的 shapefile
Last Published: July 8, 2025
摘要
Instructions provided describe how to convert the selected features of a layer to a new shapefile in ArcMap using the Export Data feature.
过程
Follow the steps below:
  1. In ArcMap, use any of the methods available in the selection menu, or use the Select Features tool Image of the Select Features tool to manually select the features of the layer to be converted.
  2. In the Table of Contents, right-click the name of the layer with the selected features to convert.
  3. Select Data and then Export Data to open the Export Data dialog box.
Image of the Export Data context menu
  1. From the Export drop-down list, select and click Selected Features.
  2. Click the Browse button next to the Output Feature Class text box.
Image of the Export Data dialog box
  1. In the Saving Data dialog window, select the output folder. Name the output and from the Save as type drop-down list, select Shapefile. Click Save.
Image of the Saving Data dialog window
文章 ID: 000002438
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
