操作方法
操作方法:在 ArcGIS Pro 中计算跨表面的线要素的坡度
Last Published: July 21, 2023
摘要
The properties of an elevation surface can be used to determine the slope of each segment along a line feature across the surface using the Add Surface Information tool. For example, calculating the slope of a hiking trail or a proposed road based on the spatial and elevation information derived from a raster layer. The slope at each cell of a grid is used to determine the slope of the line section crossing that cell. The tool attributes line features with the following slope information:
  • Minimum slope is obtained from the segment whose value is closest to 0, or horizontal grade.
  • Maximum slope is obtained from the segment with the largest calculated value.
  • Average slope is obtained by weighing each slope by its 3D length, then determining the average. This results in longer segments having a greater influence on the resulting value over shorter segments.
过程
The Add Surface Information tool requires the 3D Analyst or Spatial Analyst license.
  1. In ArcGIS Pro, create a new project, and add the line feature class and elevation data. The elevation data can be in the form of an LAS dataset, mosaic, raster, terrain, or TIN surface.
  2. Optionally, split the line features at their vertices using the Split Line At Vertices tool. Splitting the lines allows the slope to be calculated for each line segment.
  3. Calculate the slope of the line features using the Add Surface Information tool.
    1. For Input Features, select the line feature class.
    2. For Input Surface, select the surface layer containing elevation data.
    3. For Output Property, check the check box for the spatial information to be written to the line feature's attribute table.
    4. If necessary, select a suitable interpolation method under Method.
    5. Click Run.
The Add Surface Information tool.
The image below shows the minimum, maximum, and average slope values of each line segment in percentage units (grade).
The slope values for each line segment.
文章 ID: 000025428
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
