问题
问题:无法使用 Personal Use 订阅登录到 ArcGIS Pro
Last Published: August 5, 2025
描述
Starting July 22, 2021, changes were made to ArcGIS Personal Use subscriptions that require users to update their ArcGIS Online details.
原因
解决方案或解决方法
To continue using ArcGIS Pro as part of an ArcGIS Pro Personal Use subscription, follow the below steps:
  1. Log in to ArcGIS Online
    • Use the same credentials used to log in to ArcGIS Pro
  2. Once logged in, follow the prompts to Update user type, as shown in the following image:
  1. Once updated, log in to ArcGIS Pro
If the issue persists, follow the steps below:
  1. Log into ArcGIS Online
  2. Select Organisation.
  3. Select Licenses.
  4. Select Manage next to any expired licenses and remove by toggling the switch to off, and close the pop-up window.
  5. Select Members in the top tab.
  6. In the same row as your username click the options ellipsis (More options), and click Manage User Type.
  7. Select the box under User Type.
  8. Select GIS Professional Advanced.
  9. Select Save.
You should now be able to use ArcGIS Pro.
文章 ID: 000026122
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
