エラー
データ ストアの構成に失敗しました。 拡張エラー メッセージ: タイル キャッシュ データ ストアを構成できませんでした
Last Published: April 24, 2024
エラー メッセージ
The default installation location for ArcGIS Data Store on Windows is C:\Program files\arcgis\datastore. If ArcGIS Data Store is installed on a non-default drive on Windows computers, the configuration of the tile cache data store may fail with the following error:
Error:
Attempt to configure data store failed.. Extended error message: Failed to configure tile cache data store. Extended error message: Internal Server Error.
原因
This error is associated with a known bug, BUG-000101650. When installing ArcGIS Data Store to a non-default drive, the folder's name cannot contain spaces.
This bug affects ArcGIS Data Store 10.3.1 through 10.6. The behavior is resolved with ArcGIS Data Store 10.6.1.
解決策または対処法
Use one of the following workarounds to resolve this issue.
Install ArcGIS Data Store to the default drive
When installing ArcGIS Data Store, select the default C:\ drive as the installation path. The default path is:
C:\Program Files\ArcGIS\DataStore
Install ArcGIS Data Store to a non-default drive
When installing ArcGIS Data Store to a non-default drive, ensure the folder name does not contain spaces. The following is an example of a non-default installation path:
D:\arcgis_datastore_install_dir
Alternatively, install the data store to a default drive, and move the contents to the desired location using the changenosqldslocation utility:
  1. Install ArcGIS Data Store in the default drive. The default path is:
  1. During installation, ensure the data store directory is configured to the default C:\ drive. For more information on the installation process, refer to ArcGIS Enterprise: Install ArcGIS Data Store.
  2. Once the installation completes, the Data Store Configuration wizard launches. Use the configuration wizard to create the tile cache data store. For more information, refer to ArcGIS Enterprise: Create a data store using the Data Store Configuration wizard.
  3. Once the data store is configured, execute the changenosqldslocation utility via the Command Prompt to move the tile cache data store to the desired directory. Refer to ArcGIS Enterprise: changenosqldslocation for more information. When prompted, enter the desired location following the format below:
<drive>\<directory>
記事 ID: 000015832
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
