方法
フィールド演算を使用してラインの方向の計算をバッチ処理
サマリー
The direction of multiple line features can be calculated from their start and end point coordinates by using the Field Calculator.
手順
The instructions provided describe how to calculate the line direction of multiple features using a batch process.
  1. In the attribute table of the line features, add four new fields: START_X, START_Y, END_X, and END_Y. Set the field type for these fields to Double.
  2. Use the Calculate Geometry function to calculate the X and Y coordinates of the line's start and end position into the four new fields.
  3. Add another new field to the attribute table and name this field NorthAzimu. Set the field type to Double.
  4. Calculate the NorthAzimu field with the following Python expression. Refer to the code and image below.
90-math.degrees(math.atan2(( !END_Y! - !START_Y! ),( !END_X! - !START_X! )))
formula shown in the field calculator
  1. To convert from North Azimuth to Quadrant Bearing, add another new field: Quadrant; set the data type to String.
  2. Calculate the Quadrant field by using the Python code block, as seen below. Refer to the image and ensure each item is highlighted appropriately in the Field Calculator window before running the code.
def quadrant(NorthAzimuth):
    if ((NorthAzimuth>=0) & (NorthAzimuth<90)):
        quad = "N "+str(NorthAzimuth)+" E"
    elif ((NorthAzimuth>=90) & (NorthAzimuth<180)):
        quad = "S "+str(180-NorthAzimuth)+" E"
    elif ((NorthAzimuth>=180) & (NorthAzimuth<270)):
        quad = "S "+str(NorthAzimuth-180)+" W"
    else:
        quad = "N "+str(360-NorthAzimuth)+" W"
    return quad
記事 ID: 000015375
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
