ERREUR
The default installation location for ArcGIS Data Store on Windows is C:\Program files\arcgis\datastore. If ArcGIS Data Store is installed on a non-default drive on Windows computers, the configuration of the tile cache data store may fail with the following error:
Error: Attempt to configure data store failed.. Extended error message: Failed to configure tile cache data store. Extended error message: Internal Server Error.
This error is associated with a known bug, BUG-000101650. When installing ArcGIS Data Store to a non-default drive, the folder's name cannot contain spaces.
This bug affects ArcGIS Data Store 10.3.1 through 10.6. The behavior is resolved with ArcGIS Data Store 10.6.1.
Use one of the following workarounds to resolve this issue.
Install ArcGIS Data Store to the default drive
When installing ArcGIS Data Store, select the default C:\ drive as the installation path. The default path is:
C:\Program Files\ArcGIS\DataStore
Install ArcGIS Data Store to a non-default drive
When installing ArcGIS Data Store to a non-default drive, ensure the folder name does not contain spaces. The following is an example of a non-default installation path:
D:\arcgis_datastore_install_dir
Alternatively, install the data store to a default drive, and move the contents to the desired location using the changenosqldslocation utility:
<drive>\<directory>
ID d’article: 000015832
Commencez à discuter maintenant
