PROCÉDURE
renseigner un champ de date avec une date actuelle à l’aide de Python
Last Published: July 20, 2023
Résumé
In ArcGIS Desktop, a date field can be populated with the current date using the Field Calculator in ArcMap or the Calculate function in ArcGIS Pro. The Python parser in the field calculator provides the time.strftime('%d/%m/%Y') function to do so. Alternatively, the current date can also be populated using the UpdateCursor() function.
Procédure
The following steps describe how to populate a field with the current date using a Python script.
  1. Import the necessary modules.
import arcpy, datetime
  1. Specify the location of the geodatabase and the desired field.
fc = r'C:\Test\Test1.gdb\Feature_1'
field = "Date_Field"
  1. Start a loop with the UpdateCursor() function to populate the selected field with the current date.
with arcpy.da.UpdateCursor(fc, [field]) as rows:
    for row in rows:
        rows.updateRow([datetime.date.today()])
The following shows the full script:
fc = r'C:\UsersUSER1\Desktop\Data\Database1.gdb\Sample'
    for row in rows:
ID d’article: 000023088
Obtenez de l'aide avec l'IA
Résolvez rapidement votre problème avec le chatbot Esri Support AI.
Commencez à discuter maintenant
Informations associées
En savoir plus sur ce sujet
