PROBLEMA
Config.db no se actualiza cuando el puerto Mongo se cambia del predeterminado en el postinstalador
Last Published: April 29, 2024
Descripción
When the default MongoDB port 27017 is changed in the ArcGIS Monitor post-installer, only one of three entries in config.db is updated. As a result, the ArcGIS Monitor Server service stops running.
Causa
A connection is not possible due to mismatching port entries.
Follow the instructions provided to fix this issue.
  1. Start ArcGIS Monitor Administrator.
  2. Navigate to File > Open, and select the config.db file.
  3. On the Mongo tab, update the Mongo Port number to the desired port.
User-added image
  1. Click File > Save.
  2. Restart the ArcGIS Monitor Server service.
Id. de artículo: 000017589
Obtenga soporte con IA
Empieza a chatear ahora
Descubrir más sobre este tema
Ir a opciones de descarga
