CÓMO
Realizar la desautorización sin conexión de las licencias para ArcGIS for Desktop y ArcGIS Engine
First Published: May 5, 2016
Last Published: September 7, 2023
Resumen
To make ArcGIS for Desktop and ArcGIS Engine licenses available for use on other machines, it is necessary to deauthorize them.
Deauthorizing licenses using the offline method can be done without the client machine requiring direct access to the internet, which is useful for machines without such access, or where the online method fails.
Procedimiento
Deauthorizing concurrent-use and single-use licenses uses essentially the same workflow. The main difference is where the Software Authorization Wizard is accessed, which is used to perform the deauthorization. Concurrent-use licenses use the Esri License Manager, whereas single-use licenses can be managed via the ArcGIS Administrator program.
If the machine on which the software was originally installed has crashed, been lost, or is otherwise unavailable, please see the following article: How To: Recover lost licenses from My Esri.
For concurrent-use licenses:
  1. Open the License Manager and select Authorization from the panel on the left.
  2. Click Deauthorize to launch the Software Authorization Wizard.
[O-Image]
For single-use licenses:
  1. Open ArcGIS Administrator and select Support Operations from the panel on the left.
    • Start > All Programs > ArcGIS > ArcGIS Administrator.
[O-Image]
  1. Under Deauthorization Method, select the second option, Deauthorize at Esri's website or by email to receive your deauthorization file.
[O-Image]
  1. Under Deauthorization Options, select the features to deauthorize.
[O-Image]
When deauthorizing concurrent-use licenses, the quantity of each license to remove can be changed by entering the appropriate value under the 'No. of Licenses' column.
  1. Under Email Deauthorization, click Save to save the deauthorize.txt file that is used to complete the process.
[O-Image]
  1. To send the deauthorization file via email:
    • ​​Send an email to authorize@esri.com, with the file as an attachment. Save the RESPS file that is emailed back.
To upload the deauthorization file to my.esri.com:
  1. Log into my.esri.com and under My Organizations select Licensing, and Additional Licensing Forms.
  2. Click Secure Site Operations and click Browse to select the deauthorization file.
  3. Click Upload.
  4. Save the resulting RESPS file and move it to the original machine.
  1. Repeat Step 1 to open the Software Authorization Wizard. Select the third option, I have received a deauthorization file from Esri and am now ready to finish the deauthorization process.
    1. Click Browse and select the RESPS file created in the last step.
    2. Click Next to complete the deauthorization process.
[O-Image]
The licenses are now deauthorized.
Please note that although the licenses are immediately available for use, this availability may take some time to be correctly displayed on my.esri.com.
Id. de artículo: 000012537
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
