Preguntas frecuentes
Yes. It is possible for system administrators to block users from installing software updates inside the ArcGIS Pro application by making the following changes to the Windows Registry. These changes prevent ArcGIS Pro from searching for updates, blocking notification messages that appear to users on startup, and hiding updates otherwise listed on the About page inside the application.
Note: If administrators prefer to only disable checking for updates on startup, refer to ArcGIS Pro: Get ArcGIS Pro software updates for more information.
Warning: The instructions below include making changes to essential parts of the operating system. Esri recommends performing a backup of the operating system and files, including the registry, before proceeding. Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution, and consult a qualified computer systems professional, if necessary.
For ArcGIS Pro version 1.x
HKEY_LOCAL_MACHINE\SOFTWARE\Esri\ArcGISPro1.0\Settings
For ArcGIS Pro version 2.x
HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISPro\Settings
Note: Changing the value to 1 allows ArcGIS Pro to search for updates.
The Software Update section displays the status, 'Checking for updates is blocked', as shown in the image below.
Id. de artículo: 000012486
Descargar la aplicación de soporte de Esri
You can also download the app to access the chatbot anytime! Download it now.
