CÓMO
Eliminar el fondo blanco de una imagen TIFF
Last Published: July 25, 2025
Resumen
Some TIFF images have a default white background. The white background is a hindrance if it blocks layers placed beneath the TIFF image, as shown in the image below.
Screenshot of the TIFF image with a white background covering the basemap underneath it in the highlighted area.
This article provides a workflow to remove the white background of a TIFF image in ArcMap and ArcGIS Pro.
Procedimiento
ArcMap
  1. In Table of Contents, right-click the TIFF layer. Click Properties Image of Properties icon.
  2. In Layer Properties, click the Symbology tab.
  3. Check Display Background Value.
  4. Set the value for each band to 255.
  5. Set the background color to NoColor.
Image showing the Symbology tab
ArcGIS Pro
  1. In the Contents pane, right-click the TIFF layer. Click Symbology Image showing the Symbology icon.
  2. In the Symbology pane, click the Mask tab.
Screenshot of the Symbology pane with the Mask tab highlighted.
  1. Check Display background value.
  2. Set the value for each band to 255.
  3. Set the background color to NoColor.
Screenshot of the Mask tab with the Display Background Value checked, the value for the bands, and NoColor being set for the background color
The image below shows the white background of the TIFF image is transparent, revealing the basemap underneath it.
Screenshot of the TIFF image with the basemap underneath
Id. de artículo: 000023222
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
