CÓMO
Desautorizar las licencias de ArcGIS Desktop y de uso único del motor después de desinstalar el software
Last Published: July 21, 2023
Resumen
Instructions provided describe how to deauthorize ArcGIS Desktop and Engine after uninstalling the software.
When moving ArcGIS Desktop or Engine Single Use software to a new machine, the software must first be deauthorized and uninstalled from the existing machine and then installed and authorized on the new machine. If the software was uninstalled without deauthorizing it, use the ArcGIS Deauthorization Tool and follow these instructions to deauthorize the software.
Procedimiento
The ArcGIS Deauthorization Tool allows users to deauthorize licenses without having to re-install the ArcGIS Desktop or ArcGIS Engine software to complete the deauthorization.
  1. Download the ArcGIS Deauthorization Tool (4.23 MB .zip file).
  2. Extract the tool from the .zip file to a temporary location on the local machine.
  3. Open the unzipped folder and run Deauthorize.bat to deauthorize licenses.
If the deauthorization process fails, refer to How To: Recover lost licenses from My Esri to recover the licenses.
Id. de artículo: 000011179
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
